wipe-on poly to cover Shellac/F.P.? http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=44089 |
Author: | powdrell [ Wed Sep 03, 2014 5:40 pm ] |
Post subject: | wipe-on poly to cover Shellac/F.P.? |
Need to cover/seal F.P. due to players chemical reaction to F.P.....wiped on 1 thin coat of mineral based polyurethane (Ace hardware brand)...seems tacky after 12 hours....other options? F.P. applied about 6 mos. ago. Prefer to not sand off shellac, rather cover it, preferably some type of wipe-on....maybe just wait a bit longer...can does say 48 hrs., also says 'quick drying'..? Thanks |
Author: | itswednesday14 [ Wed Sep 03, 2014 6:09 pm ] |
Post subject: | Re: wipe-on poly to cover Shellac/F.P.? |
Id say use Minwax and not trust a harware store brand |
Author: | Rodger Knox [ Thu Sep 04, 2014 12:05 pm ] |
TruOil goes on nicely over FP, but that's not much more protection than the FP. |
Author: | Greg B [ Thu Sep 04, 2014 1:14 pm ] |
Varnish can sometimes take a while to dry. I would give it at least another day or two. FP is generally compatible with everything, but there's a chance the oil you used could be interacting with the polyurethane varnish. |
Author: | unkabob [ Thu Sep 04, 2014 2:01 pm ] |
I have found that Danish oil should have at least three days to set or the wipe on poly (first coat) takes several days to dry. I apply the first three coats of wipe-on poly at full strength and the last three are diluted one-to-one with mineral spirits. Watch out for runs at full strength. Bob ![]() |
Author: | powdrell [ Thu Sep 04, 2014 2:29 pm ] |
Thanks for the replies (and regained confidence)....yes, the polyurethane is working well over the F.P....I see that it will take several coats and many days to cure/sand/buff but it should do the trick!!! |
